Do 10" wheels fit or what? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 03-29-2013, 02:56 PM Thread Starter
Im looking at doulas or itp 10" wheels for the back of my 700xx, it seems some people say they are dangerously close and some say they work fine? I want to run 22x11x10 tires on 10" wheels. Anyone doing this that can confirm it works?
alekfarmer is offline
post #2 of 15 Old 03-29-2013, 03:29 PM
They will fit... But, you need the correct offset and even then you need to remove the mud scrapers. With the correct offset, you'll be about 2" wider in back. As for what the correct offset is: I don't know off hand.
post #3 of 15 Old 03-29-2013, 04:25 PM
Good deal on these imo, and they fit fine. 10x7 4.0 + 3.0 $59.99 each...
http://www.rockymountainatvmc.com/p/...las-.190-Wheel
post #4 of 15 Old 03-29-2013, 08:11 PM
M Quick i have the same question,i want a 10 inch rim also the link you just posted above rims will fit, i already removed my mud scrapers. i dont know what it means by making up for the offset, what rims do you run???
xxdanxx is offline
post #5 of 15 Old 03-29-2013, 08:27 PM
Just make sure you get them for the 700, some 10s won't fit.
post #6 of 15 Old 03-29-2013, 08:55 PM
Yes the ones I posted will fit. I Have a set of these, but don't have the tires yet. So as of now I still have the oem rims with oem size Kenda kutters. The Trx has a bolt patter of 4/144. Here's a couple links to help understand bolt patterns and off sets.
http://www.realwheel.net/manage/uplo...eren_guide.pdf
http://www.rockymountainatvmc.com/do...d%20Offset.pdf
post #7 of 15 Old 03-29-2013, 09:42 PM
thanks m quick very helpfull i think i might pick up a pair of the omf reinforced once my kutters wear out, will the extra width make it slide any better?
xxdanxx is offline
post #8 of 15 Old 03-29-2013, 10:54 PM
quadmonkey700xx's Avatar
Yes they will fit with the right offset. With my tens on mine slides easier but they are also shorter tires with less side bite. so I don't know if wider with the same tire is going to help much or not. It does with a sra bike, but IRS setup, IDK
quadmonkey700xx is offline
post #9 of 15 Old 03-29-2013, 11:10 PM
Did you see the pair or rear OMF Beadlocks for sale here? And if your wanting quad to slide the corners, get the l8tonracing rear sway bar. Then it will slide even with monster size bearclaw tires.
post #10 of 15 Old 03-30-2013, 09:10 AM
i have the 9/16 maybe i should have when with the 11/16 but the kutters are brand new thats why it doesnt slide so nice its almost to much side bite
xxdanxx is offline
