GBC XC Master tires - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 04-22-2013, 08:39 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
GBC XC Master tires
Just ordered a set of GBC XC Master front 23x7x10 tires to replace my wore out razr 2 23in fronts. Just wondering if anyone had tried the new XC masters that replaced the x-Rex line. I'll post results once I get them mounted
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #2 of 11 Old 04-22-2013, 08:53 PM
IDK if he's trail tested them yet but, https://www.club700xx.com/vb/showpost...7&postcount=24
post #3 of 11 Old 04-24-2013, 08:02 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
The xc master tires came in the mail today. They look exactly like a razr 2 front. The rubber seems soft in my opinion but i have not got them mounted yet, its just an observation.
Unfortunately when I took my front wheels/tires off to take them to work I noticed my front brake pads are beyond shot!! I know the dealer is going to be expensive if i just get some replacements. Does anyone have any reccomendations for front brake pads? I found a cheap set on ebay for $16 shipped for all 4 front pads. Is this a bad idea? I don't race or anything, just need something to fit, but don't want to buy a set that wears out in a short time. The factory pads lasted me 3 1/2 years if that tells you anything.
Ds450 shock swap
EHS fuel programmer
ein is offline
post #4 of 11 Old 04-24-2013, 09:03 PM
Wow 3.5 years on fronts! I changed mine some time last year. Then wanted to do the rears over the winter. So I bought this set, only one ride on them so far but they seam fine. When I needed fronts I got waxed at the local supply shop like almost $40 for a set, but I needed them! Oh yea my rears still had like 33% left, but I changed them any way.
http://www.ebay.com/itm/Honda-FR-R-B...00867207274%26
post #5 of 11 Old 04-26-2013, 05:25 AM
If they lasted you over 3.5 years, go with OEM. The price isnt that expensive. I'd stay away from a set for 16, garauntee they wont last. If I think of it tonight, I will look to see the brand I got. I get them from my Honda shop, but it isn't OEM. I have a few sets for each of my toys. Most vital thing on there, plus when I race I'd go through a set in 2 races.
post #6 of 11 Old 04-26-2013, 06:24 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
The dealer wanted over $70 for oem brake pads for both sides front. I ended up ordering these http://www.ebay.com/itm/160933875188...84.m1497.l2649 For the money i'll give them a try let everyone else know. I got my xc master tires mounted today but I have the front breaks all tore apart and cannot test them.
Ds450 shock swap
EHS fuel programmer
ein is offline
post #7 of 11 Old 04-27-2013, 08:01 AM
Wow $70.00!! Thats makes the $40.00 I paid at my local parts shop sound like a deal! I'm sure the ones you order'd will be fine, just keep a eye on the pad wear. I've always been leery about ordering parts for the Trx700 when they list years that the quad wasn't made, but the pads I order'd were the same way, said fits 2008 to 2013!!! Also wondering if you got 3.5 years out of fronts, if you use the rears a lot, you may want to be looking at there condition.
post #8 of 11 Old 04-27-2013, 07:12 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
I never use the rears, they are like new. I just dont trail ride much anymore. thats why they lasted so long.
Ds450 shock swap
EHS fuel programmer
ein is offline
post #9 of 11 Old 05-05-2013, 11:46 AM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
Finally got some time on my fronts. They are comparable to razr 2 fronts. I was worried about them being soft but after my first ride they still had a few tits on the tread. It seems like they are going to hold up great. I had forgotten how much these tires help you get rid of the push in corners
Ds450 shock swap
EHS fuel programmer
ein is offline
post #10 of 11 Old 05-08-2013, 12:42 AM
They're one of the best tires out. Can't believe it took me this long to find out! Just raced on them for 221 miles this weekend without any issues.
