Parking brake removal .... - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 04-25-2013, 03:55 PM Thread Starter
I want to remove it to install MSR AOF Clutch Perch & Lever , what do I do with the electrical component that goes in ?
ulfheonar is offline
post #2 of 3 Old 04-25-2013, 05:33 PM
tie the wires together its the neutral safety switch if you dont it wont start in gear put some heat shrink wrap over it to seal it from the elements
post #3 of 3 Old 04-26-2013, 06:54 PM Thread Starter
thanks , I would install a kill switch tether , which wire should I cut to make easy installation ?
