25in swamp lite rear tires - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 04-27-2013, 08:23 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
I got a chance to buy a set of like new 25-11-10 swamp lite rear tires. Since I have a set of spare 10in rear rims and the swamp lite tires were only $100 for both i figured why not. Here are the pictures.
So far i have not really been able to test them. I'm still waiting on front breaks to show up and i have a 15tooth front sprocket on right now which makes it WAYYYY to high geared. I have a new chain i'm going to install and i'm going to put on the 13tooth so it should be way more manageable. So far all i have noticed is that they can throw fist sized chunks of dirt/grass when you goose the throttle in first/second.
They just barely fit on the machine, i had to grab the heel guard and bend it forward slightly in order to even fit without rubbing.
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #2 of 8 Old 04-27-2013, 08:39 PM
Quoted: 252 Post(s)
Nice find for that price!
post #3 of 8 Old 04-27-2013, 08:44 PM
if they dont rub then you ought to be able to tackle some of the 4x4 mudholes like my neighbor does on his 2 wheel drive rancher, i have seen him go thru stuff full 4x4 goes thru and all he has is 26 inch rims with mudlites on them and also the rancher has no snorkels and goes thru most stuff a 10,000$ a mud ride will do!
post #4 of 8 Old 04-27-2013, 08:50 PM
Quoted: 252 Post(s)
26" rims or tires
post #5 of 8 Old 04-27-2013, 10:01 PM
26" rims or tires
yeah i see duh! yeah he has 14 in rims and 26 in tires ! dam them the hillbilly blood!
post #6 of 8 Old 04-28-2013, 11:25 AM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
I just realized from looking at these pictures this morning that I got so excited to try these swamp lite rears I put my fronts on backwards.. oh well, that's an easy fix
Ds450 shock swap
EHS fuel programmer
ein is offline
post #7 of 8 Old 04-28-2013, 02:06 PM
Quoted: 252 Post(s)
Yea I cant really see to well in your pictures of the fronts, but I always thought just looking at the tread pattern they were backwards when on right! The way the outside tread pattern angles, just seams like it should be reversed, but I guess they know best. But the OEM dunlops thread seamed angled right, yet Razrs and the GBC angle the opposite. I can see why you installed them wrong, simply cause it looks right till you see the direction arrow on side wall!
post #8 of 8 Old 04-28-2013, 03:38 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
Got my fronts put on correctly this morning after I did all my yard work.
Still waiting on my set of front brakes to show up so I can change my chain and sprocket and brakes all at the same time.
Ds450 shock swap
EHS fuel programmer
ein is offline
