Why did my parking brake stop working? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-29-2013, 05:08 PM Thread Starter
I have a 2008 TRX700xx in lioke new condition prolly doesn't have 15-20hrs on it. It has been parked about all winter till yesterday I took it out and ran it up and down the road. Well as I got back and parked it I locked the brakes on it but it will still roll like it isn't even on. What could b the problem with it? It is like new and super clean so nothing should be corroded. THANKS!
04honda is offline
post #2 of 6 Old 04-29-2013, 08:07 PM
you must have drove off with parking brake on the smaller your rear brake pads get parking brake works less they are useles get the only way to keep it up is to keep new pads on at all times which is bs get rid of it and get an asv perch youll save weight and you wiil have chock the wheel or leave it in gear so it wont roll
post #3 of 6 Old 04-29-2013, 08:18 PM
Quoted: 253 Post(s)
Yea the parking brake sucks. It is easy enough to adjust, but will only last one ride at best till it needs adjusted again.
https://www.club700xx.com/vb/showpost...1&postcount=17
post #4 of 6 Old 04-29-2013, 08:24 PM
ein
ein's Avatar
Quoted: 4 Post(s)
You just have to adjust it every ride or so. There is a bolt sticking out the side of your rear caliper. Set your parking break, then break the jam but and righted the bolt in untill "snug" then set jam nut. Check to make sure parking break releases. Should be a 8mm and 10mm wrenches. There is also linkage up by handle bar you adjust to take up some slack
Service manual can be downloaded here
http://www.punkbandpromotions.com/Dr...e%20Manual.pdf
Another member here (Ba9801) is kind enough to host it on his server and it is the most current working link on this site for download. It will explain everything
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #5 of 6 Old 04-30-2013, 02:47 PM
The raptor 660 was exactly the same, but somehow they cured it on the raptor 700.
Mine is road legal so mine should always work, but does not !
Its up for its first test soon so will have to work then ..once a year use... haha..
rappey is offline
post #6 of 6 Old 05-01-2013, 03:14 PM
mad
The parking brake is crap and useless... If you adjust it so it holds the quad, it will also drag the pads a bit while riding... that drag will cause you to have to adjust every ride. It's easier to remove it and park in gear.
