Removing parking brake? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 05-07-2013, 04:58 PM Thread Starter
WiZkY's Avatar
I install an asv c6 clutch lever, but after removing the cable, on the rear brake caliper, did you remove all the parking brake system or just the spring and cable? My question is almost about the brake pivot, you remove it or keep it on the quad?
WiZkY is offline
post #2 of 7 Old 05-07-2013, 06:39 PM
Remove all and install a block off kit.
https://www.google.com/search?q=mod+...w=1680&bih=959
M_Quick is online now
post #3 of 7 Old 05-07-2013, 07:16 PM Thread Starter
WiZkY's Avatar
Can I find a block off plate in every shop?
450r is the same thing, like some other pieces?
WiZkY is offline
post #4 of 7 Old 05-07-2013, 09:50 PM
yes the TRX450R block off plate will fit. as much as them asv levers cost they ought to come with one!
post #5 of 7 Old 05-31-2013, 01:13 PM
I don't think so its a better idea to remove it completely. There's always present a backup like this. So, try to repair it not to remove.
John001 is offline
post #6 of 7 Old 05-31-2013, 03:14 PM
What did he say?
post #7 of 7 Old 05-31-2013, 04:17 PM
headscratch
i dont think he even knows?
