Running 12" rims in the back with stock offset (sand tires) - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 05-09-2013, 03:22 PM Thread Starter
Has anyone tried running 12" rims with the 5+2 offset. ITP and maxxis both mke a 22" sand tire that fits a 12" rim and DWT makes the 12" rim with our unique offset. OMF also can throw re-inforceing rings on these as well.
Any insight on how this set up would work is greatly appreciated.
Thanks in advance!!!
Mooser is offline
post #2 of 16 Old 05-09-2013, 04:12 PM
i wouldnt recommend it you should of bought a foreman 500 or utilityquad. sport quads arent designed for 12 inch rims . get 10 inch all the way around.
post #3 of 16 Old 05-09-2013, 05:14 PM Thread Starter
These were the 12" rims I am considering
http://www.rockymountainatvmc.com/p/...%2528Rear%2529
With these tires
https://www.denniskirk.com/rear-righ...prd/653158.sku
Both appear to be a sport quad setup...
I am considering going the 10" route but it appears that I would be over the 50" wide limitation for the trails I ride and I wanted to keep the rear stock with for sand so the rear doesn't push any more than it allready does.
I hope that better clarifys what I am trying to accomplish; not trying to turn this quad into a utility. Just thinking about a super low profile sand tire setup. :-D
Cheers!!!
Mooser is offline
post #4 of 16 Old 05-09-2013, 05:53 PM
well the 10 inch rims will make you 50 wide i dont ride sand dunes because there is none in my state and i dont think anybody else on here has went 12 all the way around maybe someone has and will chime in
post #5 of 16 Old 05-09-2013, 06:23 PM
easystreet's Avatar
Mooser, I am facing the same dilemma as you. Just got my XX back together and I'm ready to hit dunes soon. I don't want to go wider either. I may do what your doing. I need to check to see if Skat Trak makes a straight paddle 12" rim 22" tire.
The set up won't hurt the quad any, but you won't have a good flotation tire is the only problem I see. I was running 8" rims with a 21" tire on my Raptor to get excellent flotation.
Where are you riding?
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
post #6 of 16 Old 05-10-2013, 04:18 AM Thread Starter
Going to ride the silver lake dunes in MI.
I am only planning on the 12" rims in the back with 22" paddles in those maxxis blades or the same size ITP sand tire. Up front I am going to have a 10" rim with a 22" tall matching front sand tire.
The rears are 22 x 11x 12 so I don't see why you would have any less flotation than the 22x 11x 10 as the specs show the same width and height. Essentially I think this would be a similar setup to guys who have 10" rims with 20" tall sand tires as far as flotation and tire profile are concerned.
I did some measuring tonight and figured that I will be at 48" wide in the back with the 12" rim 5+2 offset and 22x11x12 maxxis blade sand rears and 2 inches wider if I go down to a 10" rim 4+3 offset with 22x11x10 tires.
Stock width with stock tires is around 46" front and back.
Starting to get a headache with all this math!!
Mooser is offline
post #7 of 16 Old 05-10-2013, 12:54 PM
easystreet's Avatar
Yes you will have basically the same roll out. The flotation I'm referring to is the 12" rim on the same diameter tire is a lower profile. Your tire won't have as much flex, squish, or rotational twist/give. A set up like this will dig a little more than float. Digging into sand is not desirable. Ask someone with Gecko's about this. lol
We have a very heavy quad, so having flotation is huge. I need to call Skat Trak in hopes of finding a rim to rim buff, 7 paddle, 23"x 12" Extreme series. I think that would be ideal for my HP and dune style.
Let me know what you try!
'08 710XX
HotCam 3
Velocity intake
PCV (dyno tuned)
post #8 of 16 Old 05-10-2013, 01:19 PM
I run ITP Sand Stars (22") on their C5 rims (12")... I got the set used from another member... ITP no longer offers the C5 rim.
post #9 of 16 Old 05-10-2013, 02:39 PM
easystreet's Avatar
Any issues with that set up? Plenty of clearance at nerfs?
'08 710XX
HotCam 3
Velocity intake
PCV (dyno tuned)
post #10 of 16 Old 05-11-2013, 12:45 PM
These are for the rear... No issues so far, but then again, I only run in the sand once or twice a year... My fronts are Razr2s with no clearance problems with my PRM side bars.
