Rider sag - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 06-01-2013, 12:32 PM Thread Starter
Jah_82's Avatar
Rider sag
Anyone know the proper way to set sag on the xx? I know you set preload by taking measurements while on and off the bike. My thing is that my preload is set all the way soft on all four springs and when I get on the bike it doesn't even sag down at all. Wondering about this and if I should try something to help get it setup right I'm 160lbs
-Oregon-
2008 Honda TRX 700xx
13T Front Sprocket (going back to 14t for sand)
Airbox lid delete
Spark arrester delete
10' rear DWT blue label with paddle for sand
Jah_82 is offline
post #2 of 5 Old 06-01-2013, 12:59 PM Thread Starter
Jah_82's Avatar
I did find a little more info here on he forum about the subject. Some reason when I initially searched for sag is yielded no results. It looks like sag on a quad is different then my supermoto.
-Oregon-
Airbox lid delete
Jah_82 is offline
post #3 of 5 Old 06-03-2013, 02:41 PM
As far as I am concerned, the stock springs are WAY to stiff. I weigh 220 and couldn't get the ride height low enough either, not even close to where I wanted it. I guess you could find softer springs, but your best bet would be new shocks all around, or at the very least new shocks up front and send the rears out to be revalved/resprung.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #4 of 5 Old 06-03-2013, 09:37 PM
Dannyboy's Avatar
yep, depending on budget you can get amazing results. I have new gt thunder front and reworked rear and absolutely love them. New shocks were $495, re-work dual rate setup for rear is $395. I was never a believer in what suspension cost until I bought these, it was worth every penny.
2008 TRX700 - Tusk Aluminum Hand Guards, ODI Rouge Grips, American Star Chromoly Tie Rods, 12T front, ITP 10" Rims with custom 4-leaf clover reinforcement, 22" Razr2's Front and Rear, Moose Fat Peg Nerf bars, GT Thunder Rear re-valve/dual rate setup
Immortal 1995 fourtraxx 300 2WD that has survived everything but armageddon
Husky TE450 street ride - stock with some new plastics
1974 Yamaha DT 125 project
Dannyboy is offline
post #5 of 5 Old 06-04-2013, 07:38 PM
Quoted: 4 Post(s)
I agree the spring are quite stiff so you have to compensate it with the shocks pre load. On adjusting the preload what you stated is correct but still it depends on your preference and usage.
kartl is offline
