Best tires for grass dragging ?? - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 06-17-2013, 11:40 PM Thread Starter
TatTooL23's Avatar
Just wondering if anyone has any experience in grass drags. Not necessarily with the 700XX just in general.
Curious what tires r the best, how much pressure, what size tire?
Any help would be great. Thanks.
Honda
TPC Trikes
RNS Powdercoating
TatTooL23 is offline
post #2 of 5 Old 06-18-2013, 07:33 AM Thread Starter
TatTooL23's Avatar
turns out its on clay. any thoughts?
Honda
TPC Trikes
RNS Powdercoating
post #3 of 5 Old 06-19-2013, 07:07 AM
Studs haha. I run the rzr 2s when I do the drags at the county fairs and what not. Lower the air pressure. If you want a good answer, talk to Eric at EHS. That is what he mainly does is drags. I don't know what kind of tracks they use down there, but he is originaly from upstate NY so he may know what to use up around here.
post #4 of 5 Old 06-19-2013, 06:58 PM
Clay hard packed and dry , Tri tracs or Hoosiers. If it was the 700xx then Carlisle turf trek ? Can't remember the name but I have a pair ,just incase.
These.
http://www.allterraintyres.co.uk/ind...1584_1597_1598
post #5 of 5 Old 06-20-2013, 08:14 AM
if its hard pack clay then hoosiers will work well but it needs to be hard like a aspalt track
4snows work well in looser clay medium packed
on grass im not sure but if you stud anything the first few passes it will hook like a mofo until grass is gone which only takes a few passes but those couple it will be a strong sob
if its a hard mix i would try getting skat track terrian trak with some studs not real cheap but think they will work well
medium-soft stuff probably a 4 snow for most general apps until you start stepping up to a paddle tire then there is a lot of factors that come into play its hard to beat a set of 4 snow they are under $250 shipped used almost always and work well most my paddle tires start at $750 and go up to $1200 a pair and you have to have 4-5 sets
EHSRACING is offline
