REAR WHEEEL BEARINGS!!!! Help !!! - Club700XX - Honda TRX700XX Forum
post #1 of 22 Old 06-30-2013, 05:22 PM Thread Starter
ok so i was going down the road on my xx maybe doing 50 ish and i notices the back left wheel was wobbeling quite a bit so i got home took it apart and i cant seep to get the bearing all the way out, it came out in pieces what can i do?? help asap
heres what it looks like
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
xxdanxx is offline
post #2 of 22 Old 06-30-2013, 05:22 PM Thread Starter
yes i removed the snap ring
xxdanxx is offline
post #3 of 22 Old 06-30-2013, 08:42 PM Thread Starter
it looks like the inner race is stuck on the knuckle? any ideas?
xxdanxx is offline
post #4 of 22 Old 06-30-2013, 08:42 PM
Just replace the bearing !
post #5 of 22 Old 06-30-2013, 08:59 PM Thread Starter
the old one is still in there i cant get it out, that is my entire problem
xxdanxx is offline
post #6 of 22 Old 06-30-2013, 09:40 PM
Quoted: 250 Post(s)
Press it out, or find something the right size, like a piece of pvc pipe and beat it out. Or there always the easy way....http://www.ebay.com/itm/2008-Honda-T...item484d5a61de
post #7 of 22 Old 06-30-2013, 09:46 PM
Quoted: 250 Post(s)
Also was just wondering if you had this side off when you were messing with the inboard joint issue?
post #8 of 22 Old 06-30-2013, 09:51 PM
Quoted: 250 Post(s)
Also fyi bearing alone is $41.00 at Rockymountain! So eBay is looking good, imo. And sometimes if you message the seller they will give you a deal. Like if you asked for both knuckle assembly's maybe $80.00 shipped. And that knuckle alone is like $200.00!!!
post #9 of 22 Old 06-30-2013, 09:54 PM Thread Starter
m_quick no i never touched this side, with the inboard joint process, i think i might go to home depot and try to get a piece of pipe or cancel my bearing order and buy that one
xxdanxx is offline
post #10 of 22 Old 06-30-2013, 10:14 PM
Quoted: 250 Post(s)
Yea I didn't think you did, you just took right side out as I remembered. And Idk 1st hand on these, but sometimes a little heat is your friend too! On my old Scrambler to remove the ball joints from the strut, you had to heat them up and they came out pretty easy.
And yea that eBay one looks like the way to go. And you can always rebuild original and have as a spare later.
