make your own grease fitting?(zerk) - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 06-30-2013, 09:20 PM Thread Starter
so i was putting around youtube and saw a guy drill a hole and use a tap and dye set to make his own threads and put in a (zerk) and or grease fitting in himself. he did this to all his a arms has anyone done this to there xx and if not why havent we yet?
xxdanxx is offline
post #2 of 4 Old 07-01-2013, 06:07 AM
A lot of aftermarket A Arms come with Zyrk fittings. The problem with them is this, depending on the AArm location, a Zyrk fitting could get broken off during full travel of the A Arm. Which is why a lot of the companys offer plugs for the locations of the fittings, so you throw the zyrk in just to grease it, then take it out and put the plug in which is recessed just a little bit. I've had both types, stock arms with out fittings, and arms with. Most of the arms I've had with fittings, it is hard to grease, as in it doesn't want to take grease at all unless you loosen the bolt up. Others, like on the XX, I just disassemble after a while and regrease the bearings. Zyrks do make life a little easier though. But I like tearing mine apart, then I can really get in there and check for damage, and wear and tear.
post #3 of 4 Old 07-01-2013, 08:06 AM Thread Starter
now on the xx could we install our own? or are we better off just taking then apart and doing it the old way?
xxdanxx is offline
post #4 of 4 Old 07-02-2013, 08:55 AM
After looking at it last night, I don't know how it would be on the back lower a-arms. But I think you def could on the rest. If I were going to do it, I'd do it right perpendicular to the ground. That would allow the suspension to fully travel with out the Zerk hitting the mounts at all. I honestly prefer to take the bearings out, that way you can inspect them. But that is just a preference. I haven't had to replace any on the XX, and I've beat mine up pretty good.
