GBC's SUCK! - Page 6 - Club700XX - Honda TRX700XX Forum
post #51 of 53 Old 10-04-2013, 02:59 PM
Needless to say, I flip Rzr2's around backwards on the rear, and if you look at the fronts, on one side you have a little more bite than you do on the other side, which is what he meant. Good luck with them. I think when the time comes to bring my XX back to life (IE ride it more than just bar hopping) I am probably going to buy a set.
post #52 of 53 Old 10-05-2013, 09:17 PM
Quoted: 242 Post(s)
Yea I see what you mean, but still think with a sport quad better traction would make it turn better. I put them on the direction as the Razr II's. If it truly doesn't matter which way they go on, then I should rotate both front and rears from left to right every so often. All 4 of these tires were easy as hell to get the bead to set. Probably only took 10 lbs of air. The set I put on the rear of the Polaris 200, were a mutha. I had to run them up to 50 lbs. to get them fully seated!
post #53 of 53 Old 01-25-2017, 02:50 PM
Quoted: 242 Post(s)
Review
Dirt Wheels magazine review from last September.
Dirt Wheels Magazine | TUESDAY TREAD: GBC XC Master Tire Test
